Lila
Message 1 of 2
BT3510 check base message
Is there anything else I can check please before I dump these? Phone started to play up a couple of weeks ago - could no longer see caller display on either handset. Then it stopped ringing.  I removed batteries on each and put them back in. Unplugged base, plugged in again, tried to link but both handsets are saying no base link - check base. The base is lit up, as though it’s working but clearly it isn’t!
1 REPLY 1
PaddyB
Moderator
Moderator
Message 2 of 2
Re: BT3510 check base message
Hi @Lila,
Thank you for posting. I'm sorry you're having problems with your BT3510
If you give the product helpdesk a call, they might be able to help you.
If your phone is within warranty:
By phone: 0800 145 6789
Monday to Friday 9.00am to 5.30pm, Saturday 9am to 2pm
By email: Click here for email support
If your product is out of warranty contact BT's recommended agent
By phone: 0800 980 8999
PaddyB
