Message 1 of 4
BT3560: Where is the 'Find' button the manual states is in the base unit?
The manual states to locate all handsets registered to the base station"Press 'Find'" on the base unit, My units (Base +3) were delivered yesterday and the bas eunit does not have a 'Find' button. Is there another way of paging all the units (to locate a misplaced one)?
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: BT3560: Where is the 'Find' button the manual states is in the base unit?
Is it this underneath?
Message 3 of 4
rbz5416, It is indeed. Many thanks for your expertise. It's a very different 'button' from that described in the User Guide.
Anonymous
Not applicable
Message 4 of 4
Had to be one hidden somewhere as the same button is used to pair new handsets. No idea why its location isn't shown in the manual though.
