MrsPem
Message 1 of 2
BT4500 and BT4600
Bought BT4600 triple set - replacing BT4500 - however my BT4500 handset and base(the one which needs plugging into the phone socket) still works. I have another phone socket so can I use/register this to my new BT4600
1 REPLY 1
Devon_Dave
Distinguished Guru
Message 2 of 2
Re: BT4500 and BT4600
Yes, you can register the 4500 to the 4600 system
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
