Message 1 of 5
BT4600 tri set
I've purchased a new BT4600 base unit with 3 phones. My old one was faulty.
I want to transfer the numbers from the old base unit to the new base unit. Can I do this?
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: BT4600 tri set
Sadly not.
Message 3 of 5
Re: BT4600 tri set
😒thanks for the reply x
Anonymous
Not applicable
Message 4 of 5
Re: BT4600 tri set
A slight silver lining is you should be able to register as many of the old handsets as you need on the new base, up to a maximum of six.
Message 5 of 5
Re: BT4600 tri set
Ohh yes I can...Good idea ta x
