Message 1 of 4
Broadband Hub
I have no more ports left on my BB Hub. Is there a multi port adaptor  or similar I can use to connect my phone for the digital voice change over.
3 REPLIES 3
Message 2 of 4
Re: Broadband Hub
This is what you need:
https://shop.bt.com/products/bt-digital-voice-adapter-100121-GN1T.html
User Guide: https://www.bt.com/content/dam/bt/help/user-guides/Digital-Voice-Adapter-userguide.pdf
Otherwise, if you get a Smart Hub 2, I believe existing phones plug into the dedicated green port on the back, assuming you can get close enough to plug in directly:
Smart Hub 2Smart Hub 2
If you are using multiple corded phones you need to buy a digital adapter for each one, or talk to BT about getting some Digital Voice handsets that connect directly to the Smart Hub 2 wirelessly (the hub contains something called a DECT base station).
More instructions relating to Digital Voice are here: https://www.bt.com/help/landline/digital-voice-migration
BT Smart Hub 2 | Halo 3+ | BT TV Pro | Sky Q | Apple TV 4K | LG OLED
Message 3 of 4
Re: Broadband Hub
@Reghughes Digital voice does not use any Ethernet ports, your phone connects to the phone socket on the back of the Smart Hub 2.
Message 4 of 4
Re: Broadband Hub
Thanks I didn't realise that.
