FnP223
Message 1 of 2
Bt landline failure causes alarm to go off randomly
There has been a failure with the landline in my house which is causing the alarm to go off randomly, and it won’t be fixed for a few days, this is especially annoying when I’m trying to sleep. Any way to fix it or to silence it a further 100 pounds would be needed.
1 REPLY 1
NeilO
Moderator
Moderator
Message 2 of 2
Re: Bt landline failure causes alarm to go off randomly
@FnP223 Sorry about that delay getting back to you, I hope the fault has been fixed? With regards to disabling or silencing the alarm only your alarm company would be able to help you with that.
