Message 1 of 10
Call Blocking
Hi there,
I hope someone can help as this has been driving me mad for weeks now.
I have the BT call blocking phone and when it was bought all the numbers of friends and family were added to the contacts list and could get through without the vetting process. However I changed my telephone provider from Sky to BT and since then every call has to go through the vetting process - even  my daughter who is in my contacts, marked as VIP and in the speed dial  list too.
I'm struggling to see how to  change things in the settings so that this stops happening.
We've been through  the  contacts  list to make sure that all friends and family are  on the 'VIP' list but it's not working.
I've set up Caller Display with my new BT account and still no joy.
Do I need to reboot the whole phone system and start again? if so, how?
HELP!
Thank you in advance
Alma
Tags (1)
9 REPLIES 9
Message 2 of 10
Re: Call Blocking
@APSQuin
Please check to see if Caller Display is switched on by entering the
code * # 234 #. If it's active you'll get the message Caller identity will
be displayed.
Message 3 of 10
Re: Call Blocking
when you changed from Sky to BT were you moved to digital voice?
Message 4 of 10
Re: Call Blocking
Thanks Keith,
Apparently it's 'not available' but I did check online and it's set up in the account.
Do you know if I need to do anything to 'activate' it?
Message 5 of 10
Re: Call Blocking
hi Imjolly (great name)
I'm not sure - that doesn't ring any bells.
How would I check if I've been moved to digital voice?
Message 6 of 10
Re: Call Blocking
You would have a BT Smart Hub 2, and your phone would plug into the back of it, and not into your phone socket on the wall.
Message 7 of 10
Re: Call Blocking
@APSQuin wrote:
Thanks Keith,
If your phone plugs into the wall as normal, then its possible there is an issue with the data held in the exchange.
That is quite a common problem where the exchange configuration is lost, and is out of sync with your account.
To fix it, you need to remove the caller display option from MyBT, and progress that order.
Then wait 24 hours and add it again. That will reload the customer profile within 24 hours
Message 8 of 10
Re: Call Blocking
The phone isn't plugged into the hub so I'm guessing we're not on digital voice.
Message 9 of 10
Re: Call Blocking
Thanks again Keith, I'll give it a go.
Message 10 of 10
Re: Call Blocking
If it works, then you will get the message to say it active, when you try that code sequence again.
If it still does not activate, then there is likely to be a data integrity issue between your account, and the exchange database, and a moderator will need to investigate.
