Donsky
Message 1 of 7
Call Protect
I'm trying to follow this
"Log onto your MyBT then go to manage extras then "Manage BT Call Protect". Go to the numbers you want to delete and select "Edit" then click on "Remove from blacklist". Click "remove".
When I login to MyBT I don't see the "manage extras" option, I only see "manage service". I've tried about 4 times now to find how I edit/delete numbers in my personal blacklist but just end up going round in circles. The only reference to Call Protect I've found is a user guide which doesn't help at all.
6 REPLIES 6
Message 2 of 7
Re: Call Protect
The sequence I get is:
Log in to My Account
Scroll down to Your Products - then click on Manage
When Your products opens - click on Manage under Landline
When Your landline features opens - click on Manage under BT Call Protect
...then you should be into the editable options.
Message 3 of 7
Re: Call Protect
I've just checked and I get the same layout, sequence and functionality with Safari, Google Chrome and Internet Explorer so I don't think there are browser issues affecting what you see.
Donsky
Message 4 of 7
Re: Call Protect
Thanks for that, it worked. That first paragraph I put in obviously doesn't work even though it was copied of a previous community post.
Message 5 of 7
Re: Call Protect
BT keeps re-inventing these webpages so I'm afraid it's inevitable that advice goes out-of-date quite quickly.  Glad you've got there now.
pompey1898
Recognised Expert
Message 6 of 7
Re: Call Protect
Hi @Donsky ,
Try this link that should take you direct to Call Protect, it works for me :-
https://home.bt.com/login/loginform?TYPE=33554433&REALMOID=06-f1aca0f0-9277-1028-a2aa-843bdb4e0000&G...
John100
Message 7 of 7
Re: Call Protect
The process you describe, to manage Call_Protect seems to fail for FTTP based fibre-phones.
Presumably BT have not yet managed to work out how to provide it.
I have been waiting over 2 months for the on-line management of Call_Protect to be functioning for fibre-phones. Maybe that is why it is currently 'free'.
