Message 1 of 5
Call forwarding - can it be set up remotely?
Our landline is shortly moving to digital.  Unfortunately we are not at home as we are away caring for a sick relative (probably on a long term basis).  I am assuming that if we are not there to fit the adapter, we just won't get any calls?
If I had known that we would have been in this situation, I would have set our landline up to have calls forwarded to the landline where we are now (which I assume would have got round this digital changeover problem).  But we're not there, so that's that.
I went through to the chat, and asked if I could do this remotely.  "No."  I asked if they could do it for me.  "No."  (Only if I have a 'fault on the line'! 🤦🏻‍♀️)
This is completely ridiculous!  Surely BT are capable of doing this for me? 🤷🏻‍♀️  I mean, I am the accountholder, and I had to give a code to talk about this - I am not just some random person asking.  So rather than sit there for hours talking to a stupid AI, I thought I would come here and talk to some real people...😏  Any ideas, anyone?
4 REPLIES 4
Message 2 of 5
Re: Call forwarding - can it be set up remotely?
this is what I got when I used google but not sure if can be done remotely
https://www.bt.com/help/landline/calling-features-and-security/all-about-call-diversion#:~:text=To%2...
Message 3 of 5
Thanks - I'll take a look. 👍🏼
Edit - it looks like you can only do it from the phone.  (Which means I'll have to travel 150 miles just to do this, then come straight back - according to BT! 🙄)
Message 4 of 5
Hi
Perhaps its the way you have to tell the story so that they can give you what you need without breaking any rules:
- raise a fault saying that the phone isnt connecting now you have been moved to Digital
- tell them you cannot get home to do any testing/checking for a while
- ask the guide to put call fowarding on whilst you investigate and then when home you will tell them so that they can cancel forwarding
Just an idea.
Message 5 of 5
When my BT landline was down for a month a few months ago (no compensation yet by the way but I cannot be bothered to claim it - it ought to be automatic under ofcom rules and BT knew every week I reported it and only contacted me 4 weeks in the day it went back on.....) my first thought was could I remotely do a call forward (I was not prepared to call BT as I don't do queues and waiting etc). That was not possible.
From memory I think if you have set up the landline with call minder in a manner to access remotely that would have solved my problem but I had not done that. As soon as the landline started working my first job was doing that - setting up to receive call minder remotely - something I used to use every lunch time when working out of my office in the 1990s - dialing in to the landline using my mobile whilst in my lunch break but I have not been working away enough in the last decade to bother with that and usually people email.
I think once it went back on I then set up
