Message 1 of 3
Call guardian on DV essential handsets
I recently migrated from an analogue landline to DV and was sent 2 essential digital handsets. My main issue is that these DV handsets do not currently offer the call guardian facility that I relied on to screen calls as with my previous handsets. Is there an option for these DV handsets to have the call guardian feature enabled as the current option is either answer the call to see who is calling or ignore it and risk missing an important call?
2 REPLIES 2
Message 2 of 3
Re: Call guardian on DV essential handsets
Just plug your existing base station into the green socket at the rear of the hub and continue as before.
Message 3 of 3
The DV will not get call guardian but you can continue to use your existing phone by connecting them to the green phone socket on back of the SH2
