Message 1 of 3
Call protect settings
At the top of the screen it says, 'choose which type of calls to send to your junk voice mail'
Lower down, it says 'choose which type of calls you still want to receive'
If I DON'T WANT to receive Withheld and International calls, do I tick it or not?
2 REPLIES 2
Message 2 of 3
Re: Call protect settings
You are choosing which type of calls you DO wish to receive, so you untick the box next to those type of calls that you don't want to receive
Message 3 of 3
Thank you
