billybob99
Message 1 of 3
Calling a BT mobile
I did look but couldn't see anything, does calling a BT mobile cost the same as any other mobile from a landline
Thanks Andrew
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Calling a BT mobile
-Richie-
Guru
Message 3 of 3
Thanks Andrew
Yes, calling any mobile is chargeable, regardless of the provider.
The exception to this is if you have unlimited anytime calls addon, which gives you 1000 minutes to BT Mobile (excludes business mobiles) and half price to other mobile networks.
