kanesh
Message 1 of 13
Calls drop after 29 minutes
I had three instances, where telephone calls suddenly drop after 29 minutes into the conversation. I thought it was just a coincident. Also, there were instances where the other party could not hear my conversation for few seconds. By the way, I am using FTTP. Today, I phoned BT to report the issue. To my surprise, I was told that the 'call-dropping' is a known issue. Apparently, the calls drop either after 15 or 29 minutes. Is it possible get further information on the issue itself and the details of potential fix/workaround? Regards Kanesh
12 REPLIES 12
Keith_Beddoe
Message 2 of 13
Re: Calls drop after 29 minutes
I assume this is a fibre voice connection, where your phone is connected into the Openreach ONT, and not a separate copper pair for the phone line?
kanesh
Message 3 of 13
Yes, Fibre voice connection. The support staff mentioned that the issue is on Openreach system.
Keith_Beddoe
Message 4 of 13
Was it the FTTP team you were talking to, on 0800 587 4787 ?
It would seem to me like a router misconfiguration which is imposing a timeout. You may not pick up the same router every time.
It can be an issue with CISCO routers if they are handling SIP connections. I have seen this on PBXs some years ago.
kanesh
Message 5 of 13
I don't think so. I rang 0800800150. Should I report it to FTTP team?
Keith_Beddoe
Message 6 of 13
You could try them, as they are more likely to know about any routing issues.
As I said, its most likely a router configuration issue, and you occasionally get routed via that router.
Keith_Beddoe
Message 7 of 13
asherUK
Message 8 of 13
Issue with the CNET providing FVA, call the FTTP team and they will report it to BTO and should be fixed within a few days.
kanesh
Message 9 of 13
Thank you very much.
akitaman
Message 10 of 13
Thank you.... being the other person that posted about this earlier I'm glad I'm not the only one.... just waiting for a call back from the FTTP, didn't want to hang on in case they decided to answer after 28 minutes
