Message 1 of 5
Can I get a third Essential Digital Home Phone for my Digital Voice and Smart Hub 2?
I am using Digital Voice and the Smart Hub 2, with the two, free Essential Digital Home phones, Type A, but could do with a third one. Is this possible? I can't find it in Shop BT, only if you buy a "stand alone" set.
4 REPLIES 4
Message 2 of 5
Re: Can I get a third Essential Digital Home Phone for my Digital Voice and Smart Hub 2?
Message 3 of 5
Message 4 of 5
Thanks Keith, but I was hoping for an "Essential" rather than an "Advanced" phone.
Message 5 of 5
BT give out 1 x Alexa free or 2 x Essentials, you can buy extra handsets and have the cost added to your next BT bill.
