Message 1 of 3
Can I have a corded base station and cordless phones?
It it possible to use a corded base station (BT 2600) with cordless handsets?
2 REPLIES 2
Message 2 of 3
Re: Can I have a corded base station and cordless phones?
the BT2600 is a corded phone and does not have dect facility to connected cordless phones
if you have DV you can connect the BT2600 to green socket on back of hub and also use the DV cordless handsets supplied by BT
Message 3 of 3
Hi @MysteryMan99
If you mean, can you use a corded phone connected to one socket and a cordless base connected to another to use cordless phones then the answer is yes. You can use a mixture of corded and cordless phones.
