Taffy078
Expert
Message 1 of 4
Can we plug a new phone into one socket when an old phone is plugged into another socket?
Hello.
We are replacing three BT Edge 1500 with two BT Essenitial (both handsets and bases etc).
Both will have to be charged (via the phone sockets I presume) for 16 hours before we can use them.
Can I replace one of the existing handsets with one of the new for now and the other later i.e. will the old phone work with a new one plugged in another socket?
Regards
PS BT must be very confident there'll be no problems with them - they've removed the pre-printed sticky return label!
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Can we plug a new phone into one socket when an old phone is plugged into another socket?
??? Have you read the user manual?? if not you can find it here
Taffy078
Expert
Message 3 of 4
How embarrassing - just found it in the Quick start-up. "Plug both phone & dicking station into a power socket. Only connect to the phone socket when ready." thanks.
Anonymous
Not applicable
Message 4 of 4
No problem, and no need to feel embarrased
