mforrest
Message 1 of 6
Cancelling a fault
Hi,
I started the landline fault checker and now no longer need the fault - it was an issue on my end - now sorted. I don't seem to have any way of resolving or cancelling the existing fault? I was going to try the live chat, although can't seem to find that option.
Any suggestions?
Thanks.
5 REPLIES 5
imjolly
Message 2 of 6
Re: Cancelling a fault
There is currently no live chat so you need to phone 150 to cancel your fault and stop engineer visit
mforrest
Message 3 of 6
So it didn’t actually complete, so if I go to track my fault - it’s not there. If I try to report a landline fault again - it asks me to resume the previous fault. I’m due to migrate to fttp/digital voice on the 12th Aug, so assume it’ll just clear itself out? Only shows in My BT when I login and then says there’s no fault when I tap the message.
Thanks,
imjolly
Message 4 of 6
If you never finished reporting fault then just ignore it and wait for your FTTP
Annmac
Message 5 of 6
I have the same problem. Have you managed to sort it yet. Thank you
mforrest
Message 6 of 6
It just cancelled on its own, it went a few days before I had FTTP installed.  Just give it a week and see what happens
