Message 1 of 3
Cannot accept incoming calls
Hi. For the last few days, I've had this problem with my digital voice service.
1. I cannot make outgoing calls. There is no dial tone.
2. On incoming calls, the phone rings and the caller's number is displayed, but I cannot accept the call. Pressing the green phone button has no effect.
I have a BT hub and a BT Advanced Phone Z phone.
I've run BT's online phone diagnostics, but they didn't find anything. The internet diagnostics said that my internet connection isn't very good. But it told me a speed of over 30 Mbps, and I'm not experiencing any problems with web browsing and streaming.
Any help appreciated.
2 REPLIES 2
Message 2 of 3
Re: Cannot accept incoming calls
Power cycle the hub and the phone base …..if no difference and still NDT, try a different known working phone , (if you don’t have one possibly borrow one from a friend, neighbour or relative, or buy a cheap corded one to keep as a spare …..if that also the same (no improvement ) , report as faulty , you may need a replacement hub .
Message 3 of 3
Aha! The old switch-it-off-and-on-again. Why didn't I think of that? It worked like a charm. Thank you!
