Marc2887
Message 1 of 6
Cant receive calls from mobiles, but can from landlines
This is on behalf of my mother who has just moved from sky to BT. Her landline is working to make calls, and can receive calls from landlines. But when trying to call her from my Sky mobile, a BT mobile or an asda mobile, we're getting a "this number does not exist message". Can somebody help please?
5 REPLIES 5
imjolly
Message 2 of 6
Re: Cant receive calls from mobiles, but can from landlines
Try dialling 17070 and make sure the number you hear is your mother's number
Marc2887
Message 3 of 6
Her number is correct, she can make calls to landlines and mobiles, she can recieve calls from landlines, but when trying to call her from a mobile (no matter the network) it says the number doesn't exist. Checked and made sure do not disturb is switched off etc.
CJT80
Recognised Expert
Message 4 of 6
@Marc2887
to confirm when you or she dials 17070 the number read back is correct?
If so, was the number transferred from Sky to BT?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Devon_Dave
Distinguished Guru
Message 5 of 6
The number has not  been ported across correctly.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
NeilO
Moderator
Moderator
Message 6 of 6
Hi @Marc2887, I agree it does sound like a number port issue. I'll send you a private message so you can get in touch with the moderation team and we'll be happy to help.
