Tjbosworth
Message 1 of 4
Cant receive incoming calls
My incoming calls are all being rejected but I can make outgoing calls. Need help Asap.
3 REPLIES 3
CJT80
Recognised Expert
Message 2 of 4
Re: Cant receive incoming calls
Hi there @Tjbosworth
What type of phone are you using, corded or cordless?  Can you see what socket you have?
Does it look like this?  With the bottom half having a line accross it?
If it does do you feel able to carefully remove the bottom portion? Be careful for wires.   Once removed plug a Corded phone (if possible) in and try calling your number. What happens?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Tjbosworth
Message 3 of 4
Sorted it was the filter box. Thanks for your quick reply
CJT80
Recognised Expert
Message 4 of 4
Excellent.  Glad it sorted the issue. Smiley Happy
Kind Regards
CJT80
