Message 1 of 7
Cant set up new Alexa handset...web address is wrong, no prompt for code???
Hi. Ive followed the simple instructions but no luck. Any one out there can help please?
6 REPLIES 6
Message 2 of 7
Re: Cant set up new Alexa handset...web address is wrong, no prompt for code???
is the phone paired to SH2?
if you enter the web address at part 2 can you then log into your amazon account? ( the address does work)
Message 3 of 7
Sorry whats SH2? The phone is paired to hub on FTTP. The address provided is amazon.com/gb/code When entered I only get amazon.co.uk
If I log onto my Amazon account I dont get a prompt
TIA
Message 4 of 7
Hi @MrsP666   amazon.com/gb/code should take you to your Amazon log on screen? Once logged in it prompts you for the code.
Message 5 of 7
Thx. Once logged in to Amazon (I use Smile??) I do not get a prompt for the code
Message 6 of 7
Hi @MrsP666
I would try a different browser or clear your cache or cookies. I am using Edge on Windows 11. I get exactly the same result on my iPad using Safari.
When I go to amazon.com/gb/code I get:
Followed by:
Message 7 of 7
Thx will try that.
