Message 11 of 18
Re: Certain people can't get through to my father
Just for clarity , dialtone is the noise you hear on a landline phone when you ‘lift the handset’ before you dial the number , the question for people who call your father isn’t if they get dialtone but what tone or message is received, no tone (so silence after the number  has been ‘dialled’ , NU tone (number unobtainable) or a voice message like ‘the number you have dialled has no been recognised, please check and try again’ , TBH calling from a mobile is not ideal as they can return nothing on failed calls (therefore not much help ) calling from a landline is more likely to return some sort of tone or announcement, so if possible try a call from a landline , preferably a couple from different providers , as an example) BT/EE and Sky , or Talk Talk , Plusnet , although I appreciate that may not be easy to accomplish.
Presumably your father is now on DV (Digital Voice ) so his phone is connected to his BT router, and the problems with incoming calls began after the change from PSTN to DV , when tbis issue occurs usually it’s either the number has been ported between various providers in the past , or affects just a single mobile operator , if the number has never  been ported between various, and always been  with BT , all they can do is check the move toDV was successful, if any calls from BT /EE landlines can get through that suggests it was done .
The only example I can think of that’s similar ,  a BT customer posting on here sometime ago had an issue , some incoming calls didn’t get through , after a little investigation (asking the people who said they couldn’t get through who they used for their outgoing calls ) it was a single company, with a few subsidiary brands , BT had no way to ask them to check their routing information was correct) other networks were fine , in the end that customer had BT renumber their ‘line’ as the other company (if I remember it was his son that was the most important caller who used that company) had asked them to investigate but they were not interested in that one of their customers couldn’t get through to one specific BT number ,
Message 12 of 18
Do we yet know whether @PatrickKnight146  father has Broadband? Many people haven't  and indeed I know at least one person who hasn't and has no intention of getting it and so they'll have to have something fitted when PSTN is switched off if they still want to have a landline phone. I'm still on ADSL and shall remain so until that day comes.
We know very little about the father's circumstances in relation to how he lives i.e whether he is in his own residence  be that a house/flat etc not that it is necessarily relevant and we don't know his ability as to how much he can sort this problem out at his end.
Message 13 of 18
Welcome to the Community, @PatrickKnight146
I want to be sure we've done all we can for your Father at our end, so I've just popped you over a private message so we can take some more details around this.
Speak soon,
Peter
Message 14 of 18
@PatrickKnight146
Any further developments since a moderator intervened?
Message 15 of 18
The BT person seems to be properly on the case and the tech team will be trying one or two options. Fingers crossed.
Thanks to you and everyone else who made suggestions.
Message 16 of 18
The problem is solved!
Apparently when the digital voice was brought in in 2024 the number wasn't 'ported over' thoroughly enough or something like that.
Message 17 of 18
Thanks for the update here, @PatrickKnight146
I'm really glad to hear you managed to get that sorted, and thanks for taking the time to come back and let us know, too.
You take care,
Peter
Message 18 of 18
