Message 1 of 12
Change my landline phone number
I have recently moved my telephone provider to BT from BT Business.  When I placed the order I was told I could change my phone number from the new one given to me back to the one I had previously for 50+ years.  Can anyone advise how I can do this online?  I can't seem to find the correct place on the website.  I am set up with MyBT.
11 REPLIES 11
Message 2 of 12
Re: Change my landline phone number
@william43
I doubt you could move a number from BT Business to BT Retail, as they are separate parts of the company.
All you can do is to ask BT customer services for a re-number, but I would be surprised if they could do it.
Message 3 of 12
Hi @william43 and welcome to our community.
Are you moving to a digital voice service or is your line a copper line? Did you have the number ported to your business line previously?
Cheers
David
Message 4 of 12
I assume we have a copper line. I can’t answer your second question as I don’t understand it, sorry.
when I opened the new domestic account the man definitely said I could change the number once the new line was activated
Message 5 of 12
Thanks for getting back @william43 .
Sorry for any confusion. I was asking if the number you're wanting to keep was used for your business account?
Cheers
David
Message 6 of 12
Yes it was used for our business which is just a family farm so should never have been a business line really. We overpaid for years!
Message 7 of 12
BT would classify that as a commercial usage, so a business account would be correct. Residential accounts do not allow commercial usage.
Message 8 of 12
Technically there should be no difference between a BT business and a BT residential number. Unless it was part of a multi line group or was a direct dial number. In this instance as it was a single line number used by a farm I can't see any reason why the original number cannot be given back to you.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 9 of 12
The problem is that BT Business and BT Retail are separate, and if the farm business is still being advertised anywhere, then its still a business. If the business had stopped trading, and was now just a family residence, then a new number would be appropriate, otherwise they would keep getting calls about their business. All they need to do is to inform family and friends of their new phone number.
I think the moderators are going to have to decide on that, after taking advice from higher up.
Re-issuing advertised business numbers could have legal implications as another business could take over the number and potentially mislead customers.
Message 10 of 12
I changed my home account to business and back again to home and kept the same number throughout.
