Message 1 of 2
Cloud Voice Phones - can't hear person on other end, faint high pitched whine
Hello,
Hoping someone might be able to help. We're having an issue with our phones in that calls can be made and received, but no audio is coming through on either end. If listening carefully a faint high pitched noise is audible whenever you attempt to make or answer a call.
Any suggestions for a fix?
Thanks!
1 REPLY 1
Message 2 of 2
Re: Cloud Voice Phones - can't hear person on other end, faint high pitched whine
Hi.
BT Cloud Voice is a Business Product. Can I suggest you post this question on  Bt Business Forum
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
