Message 1 of 8
Confusion about land line and Digital Voice
Can I use a regular analogue phone with Digital Voice phone line?
I would like a landline that I can use in emergencies. Is it possible to do it with Digital Voice?
7 REPLIES 7
Message 2 of 8
Re: Confusion about land line and Digital Voice
Message 3 of 8
@Calypso Yes you cam  plug you existing phone into the phone socket at the rear of your home hub (probably covered by a sticker)
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 8
after moving to digital voice if you get a power cut then your hub will not work and therefore neither will your DV phone.  you would need to get a UPS so you can keep hub connected to internet and DV phone working
Message 5 of 8
What is a UPS?
Message 6 of 8
@Calypsowrote:
What is a UPS?
Uninterruptible Power Supply.
If you have FTTP then you'll need to keep both the SH2 & ONT live to make alls.
Message 7 of 8
Thanks for all your advise guys.
I think I have now sorted my wi fi and Tv now. Unfortunately I wasn’t able to keep my normal phone line, if I wanted broadband, as they’re getting rid of all normal analog telephone wires and they’ll be obsolete in 2025. So I have to go with the Digital Voice. 🥺
Very confusing.
Message 8 of 8
It's the phone system that's being phased out. The wires will hang around for some time even if the 2025 target is met.
