Message 21 of 24
Re: Connection problem digital voice
Hi Thanks for that, my phone is showing "On Line" but no dialing tone so I will give it a go
Tacker
Message 22 of 24
Did a reboot fix it?
Message 23 of 24
Hi Thank you, for your advice, a reboot did partially fix it, still having problem with zero dialing tone, working ok apart from that thanks again
Tacker
Message 24 of 24
Hi
Thanks for your reply
Yes I removed the label to find the socket, my phone is very new and has RJ male socket
Tacker
