Message 1 of 4
Converted to BT home phone standard now can't login to my account
HELP! I was converted to BT home phone standard but now I can't login to my BT phone account.
I use the normal login but it now says BT wants to check my email address, it sends a code to my email but no code ever shows up so I am in a loop.  I can supply more detail if  a rep can pick this up please ?
thx
John
3 REPLIES 3
Message 2 of 4
Re: Converted to BT home phone standard now can't login to my account
Try phoning CS 03301234150 and they should be able to help you
Message 3 of 4
As 'Home Phone Standard' is for those without broadband, I think BT assume that customers on it won't need an online BT account (even if they had one previously). Think this has been posted before.
Message 4 of 4
Thanks Tim123,  I did call repair and they fixed it,  I now have access.  I expect they only add accounts that get complained about.
