Message 11 of 19
Re: DECT phone charging issues
We have socket type 4 on your image. Broadband and voice is with Virgin ISP.
House DECT set up is as follows: There is a phone socket downstairs for the old landline phone. There are two phone sockets upstairs for the DECT phones.
Recently the second DECT handsets stopped working, so we bought new Everyday DECT phone with base station. We didn't think we needed new base station but you had to buy DECT phone + base station.
The old DECT handset still works and you can still pick up outside calls on it.
This isn't the case with the new DECT handset. After charging up the DECT phone (charge the batteries first etc etc), you now put the new DECT handset in the base station and it only says POWER UP BS or OUT OF RANGE.
I have tried REGISTERING - BY pressing the FIND button on the base station but when you press the menu button on the handset to register - I'm not sure that's what you do but they are the only half-relevant help articles I can find - nothing happens - you can't use the menu button to register the phone.  Sounds like we need to register the handset to the base station some other way
So, I have a new DECT phone that doesn't work. There are no decent help articles anywhere ......but surely I can't be alone in having switched to a different ISP? Why are there NO decent help articles anywhere? Why does the old DECT work but the new one doesn't??
Anonymous
Not applicable
Message 12 of 19
Hard to follow but it seems as though you're still using the old base station, which is why the original handset works. In which case you need to plug in the new base station, just to the mains, & deregister the new handset. You should then be able to register it with the old base.
Message 13 of 19
I'm not going to disconnect the old base station + handset ......because that at least works.
The two base stations and phone connections are in different rooms
I have set up the new base station with the new DECT handset - and it is doesn't work. So why doesn't it work?
What do I do now?
Anonymous
Not applicable
Message 14 of 19
I didn't say anything about disconnecting the old base.
But this is still confusing. So you have both base unit powered up & conncted to the phone line?
Message 15 of 19
If you have broadband and voice with virgin as you posted do you still also pay BT for the use of another phone?
Message 16 of 19
Yes all base stations are connected to the mains power and plugged into phone sockets.
Message 17 of 19
I don't know; it's an old BT system set up decades ago.
All I know is the old base station and phone works well enough and the new ones (also BT Everyday phones/base stations) don't.  Surely I can't be alone in finding that we suddenly need to replace an old DECT phone that fails?
Message 18 of 19
Maybe the socket is the issue. Swap the phones into the different sockets, if the working phone set no longer works when connected to a different socket that will tell you the socket is the problem not the phone.
Anonymous
Not applicable
Message 19 of 19
It's possible that one base is interferring witht he other.  You wouldn't normally run two base stations, especially inclose proximity.
If you're saying that the new handset reports out of range when on the new  base then it's either interference or faulty.
You might be better off returning it & buying eitheer just a handset or something more capable like the BT4600 to repace the old system altogether. You may be limited to used/refurb for a replacement hansdet.
