Aljaha
Message 1 of 3
DV and cordless phones
Although of no concern to me at the moment, not having FTTP or DV a question occurred to me having read a number of questions and answers.
Could you de-register a cordless phone from its base station and re-register on Smart Hub 2, to use DV, probably losing some of the functions?
2 REPLIES 2
spile
Message 2 of 3
Re: DV and cordless phones
BT have a DeCT adapter that you can order for no charge if you have been moved to DV.
Devon_Dave
Distinguished Guru
Message 3 of 3
Or you could just plug the dect base station into the green pstn socket on the rear of the smart hub.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
