joesoap007
Message 1 of 2
Decor 2600 Failure
My BT Decor 2600 has failed this morning.
I can make and receive calls but all other features and the display screen are not working.
I have unplugged power and phone lines, reconnected but no change.
Are there any code inputs to reset the device?
Or, if not, is there any way to recover the 160 contacts stored on the phone?
Tags (2)
1 REPLY 1
joesoap007
Message 2 of 2
Re: Decor 2600 Failure - Chump
Silly error here, I confess. The problem was power. The phone has been plugged into a UPS [Uninterruptable Power Supply] which failed and I did not realise. So unplugging and re plugging made no difference. I only found out when I tried to use a printer connected to the same UPS. So the remedy was plug direct to power socket and now spend twice as much to replace the UPS. 🙄
