Message 1 of 5
Digital Voice _ Answer phone 1571
I have just started using Digital Voice.
Old style phone, I need to call 1571 to listen to any voice messages.
When calling 1571 is this free or a chargeable call ?
Thank you.
4 REPLIES 4
Message 2 of 5
Re: Digital Voice _ Answer phone 1571
Message 3 of 5
1571 is a free answer service with Digital Voice, listening to your messages is also free.
@jac_95these posts don't help with specific questions btw, the link you have only mentions the following for 1571 which do not answer the OP's questions :
1571 answering service is enabled by default with DV, therefore if using an answering machine, 1571 should be set to maximum number of rings and the answering machine to a fewer number to allow the answering machine to cut in before 1571.
Message 4 of 5
@-Richie-
@jac_95 auto post is to try and help the general questions which new DV customers were asking and the FAQ were a result of the same repeated questions
Message 5 of 5
Thanks for the updates all sorted, especially Ritchie who answered my query.
