SteveR1260
Message 1 of 3
Digital Voice Speed Dial
Just had Digital Voice and somebody has entered random numbers into some of the speed dial entries.
I have searched, and can find nothing on how to delete or enter valid numbers to replace these entries.
The information on using the system is almost non-existent.
Appreciate any help
2 REPLIES 2
RIC9380
Message 2 of 3
Re: Digital Voice Speed Dial
It's in the manual:
Delete a speed dial entry
1 Press then the right navigation
button.
2 Scroll down to the entry you want
to delete and press Options.
3 Scroll down to Remove and
press Select.
You’ll get a message
confirming you’ve deleted the speed
dial entry
SteveR1260
Message 3 of 3
Hi, thanks for the feedback.
Managed to locate the actual manual, and this is the information for deletion of speed dial entries. Tried it out and works as stated.
Hope it helps others. Many thanks.
