- Mark as New
- Bookmark
- Subscribe
- Subscribe to this message's RSS Feed
- Highlight this Message
I have a strange fault, I ham using 2 new Advanced Digital Handsets on Digital Voice. I have 8 speed dial numbers stored all the numbers are correct in the contacts, one of the numbers fails because the 5th digit is missing when dialled using the speed dial although the contact entry is correct, I have deleted both the contact and speed dial and re-entered them with no change, it appears to fail if the number programmed has a digit 3 in the number in the 5th position the code concerned is 01873 XXXXXX. I have got over this problem by entering the number in international format 00441873 XXXXXX and because the 3 in now not in the 5th place it works, any suggestions please?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
Re: Digital Voice Speed dial error
Thanks for the post and welcome to the Community.
This is an automated response as I can see you have a question about BT’s Digital Voice service. Rather than waiting for a response from the Community, you may find an answer to your question by using the search bar on the Community homepage. We also have a thread that contains a wealth of info related to BT’s Digital Voice, click this link to take a look, Digital Voice FAQs.
If you have already looked for the answer to your question and have not found anything that can help, then please ignore this message. One of our Community members will be along shortly to help you further.
- Mark as New
- Bookmark
- Subscribe
does it connect ok if you just enter the phone number using keypad?
- Mark as New
- Bookmark
- Subscribe
yes
- Mark as New
- Bookmark
- Subscribe
does it also work if you select the contact from the list without using speed dial in other words the problem is with speed dial not with the contact
- Mark as New
- Bookmark
- Subscribe
- Mark as New
- Bookmark
- Subscribe
I hope I have done this correctly as I wanted to update my message. I have found out the reason for the failures, if the speedial is entered as METHOD 1 it fails by dropping a digit, I have a friend who has also tried this method and he also gets a failure so there seems to be a design fault or software problem. METHOD 2 works ok.
METHOD 1 (fails)
Open contacts list
Select name to add speedial to
Options
Set speed dial
Select
Select speedial location
Select
METHOD 2 (works ok)
open contacts list
Right click navigation button to list speedials
Options
Add speedial
Enter the telephone number
Save
Saved!
- Mark as New
- Bookmark
- Subscribe
Does this mean that the Speed dial listing has to be numeric only and that the name associated with that number cannot be registeted?
- Mark as New
- Bookmark
- Subscribe
Update
My METHOD 1 allows you to add a speed dial to the speed dial list but drops a digit from the number, I like many I'm sure used the menus to enter a speed dial not following the User Guide. I have since followed the method in the User Guide:
Open contacts list or enter from contacts list is as follows:
Right click on the navigation button
If no speed dials in list click add
If there are speed dials in list click options
Add speed dial
Options
Choose - from contacts
Select
Select a speed dial location number in the list
Select
That works OK, no digit dropped and puts the name in the contacts list, if you need to put a speed dial in the list that is not in the contacts list use method 2 which only shows the number in the list.
It appears I made the error by not following the User Guide but as I have said lots wont and fall into the trap I did perhaps a software update could stop it being possible to add the contact as I did using METHOD 1.
