rsmyth492
Message 1 of 6
Digital Voice adapter
Hi there,
Would I be able to plug in a 2-way splitter into my BT Digital voice adapter, and connect 2 telephones to the same adapter?
Also, are BT extension cables compatible with Digital Voice? I have one that is 2m and has got a BT plug on one end, and a BT socket on the other.
Many Thanks
Regards
Ryan
If this reply was helpful, please leave a like, or if I answered your question, please click 'mark as answer. Many thanks
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: Digital Voice adapter
@rsmyth492
Yes to both questions.
rsmyth492
Message 3 of 6
Many Thanks for your reply.
Regards
Ryan
Keith_Beddoe
Message 4 of 6
And you can also use the phone socket on the back of the smart hub 2.
rsmyth492
Message 5 of 6
Hi there,
I knew that, just wasn't sure if you could plug 2 telephones into the 1 digital voice adapter.
Many Thanks
Kind Regards
Regards
Ryan
Keith_Beddoe
Message 6 of 6
Any modern phones plugged into the splitter should be fine. Really old phones with a mechanical bell are unlikely to work anyway, as they do not use tone calling.
