Message 1 of 4
Digital Voice with Business Smart Hub 2
I have a Home Smart Hub 2 with BT Digital Voice handset. These work correctly.
Recently I decided to replace my Home Smart Hub 2 for a Business Smart Hub 2 so that I could enabled bridging mode.
I read in the specs for the Business Smart Hub 2 that like the Home version, it also supports DECT. However I am not able to complete the set up of BT Digital Voice handset with the Business Smart Hub 2. I am able to pair the devices together, however the set up stalls after that.
Has anyone been able to set up a BT Digital Voice handset with the Business Smart Hub 2?
3 REPLIES 3
Message 2 of 4
Re: Digital Voice with Business Smart Hub 2
Message 3 of 4
@ChrisSE14
You may like to read this thread https://community.bt.com/t5/BT-Devices/Using-a-BT-Business-Smart-Hub-2-with-BT-Residential-Broadband...
I would suspect that its not possible in bridging mode.
Message 4 of 4
Cheers Keith. The OP did not post back the outcome.  I'll see if I can chase for a follow up on that thread.
