Message 1 of 7
Digital Voice
I have FTTP provided through a hybrid drop-wire with fibre providing my broadband through a Smart Hub 2 and a copper pair for landline phone.  BT plan to convert my landline to Digital Voice. Currently my landline terminates on a NTE in my garage.  No phone is plugged into the socket on the front of the NTE and my phone network is wired into the back of the NTE.  My phone network consists of a DECT system with 3 handsets and a single hard-wired phone.  My understanding is that my hub supports a socket for old-style analogue phones and a built-in DECT terminal.  Can these be used simulatneously for Digital Voice?  On conversion day, I plan to move the existing DECT base unit to a position adjacent to my hub and plug it into the broadband hub's phone socket (as advised by BT although this is not terribly clear) and associate my hard-wired phone with the broadband hub through my free Digital Voice Adapter. Will this work OK?
6 REPLIES 6
Message 2 of 7
Re: Digital Voice
@billm
Yes, the phone socket on the Smart Hub 2 supports any existing phone, and can be used as well as the home hub DECT.
Message 3 of 7
Re: Digital Voice
@Keith_Beddoewrote:
@billm
Sounds promising.  Do you or does anyone know please if there's any instructions on how to make that DECT hub work and register phones to it?  I've searched and searched and can't find any instructions so I'm suspicious it's a future capability.
When I interrogate the hub it just shows this greyed out phone icon saying 'Not Configured'
Message 4 of 7
Re: Digital Voice
You need to wait until Digital Voice is activated.
Message 5 of 7
Re: Digital Voice
Aha
Thanks for the quick reply Keith
Message 6 of 7
Re: Digital Voice
Thanks for the replies.  I'm not seeing anything about Digital Voice on my dashboard unlike Stevek1311 who at least has something, albeit greyout.  I guess that box will appear once once something is plugged into the Digital Voice port and/or the service is activated?
Message 7 of 7
Re: Digital Voice
Apologies.  Got the greyedout telephony box.  Wasn't looking at the Home page!!!!!
