Message 1 of 5
Digital phone voicemail not taking messages
Hi, I have had the Essential  DV phones for 4 weeks now . It allows  you to leave a message but when I enter 1571 it states no messages . Can anyone offer a suggestion to fix this?  many thanks
Andrew
4 REPLIES 4
Message 2 of 5
Re: Digital phone voicemail not taking messages
do you get the messages if you press the icon on right of handset like a cassette
Message 3 of 5
Hi
Thanks for reply , I have since discovered that the messages are going to my mobile , yet I don't recall setting it up to do this . I have now cancelled call diversion and its now going to BT voicemail . Can I ask  is it possible to dial into the BT voicemail from another phone ie a mobile ?
Message 4 of 5
according to google
Dial 1571 from your home phone and select Option 3 to choose your own personal 4 digit PIN. When you're away from home (in the UK or abroad) dial your home number and wait for Voicemail to answer. Then press the * key and enter your PIN to access your messages.
Message 5 of 5
All done thank you for all your help
