Message 1 of 5
Digital voice from Telephone over internet
I currently have FTTP with no copper lines to a relatively new build home. Im on Halo 3 and have a BTSmarthub 2. My phone is currently plugged into Tel 1 on the modem, so phone over internet. I understand our current BT8500 will work if I plug it directly into the Smarthub DV port when we are switched over. Am I right in think is that all I need to do is unplug from Tel 1 on the modem and replug into the DV port on my Smart hub when we get told to switch. I have tried asking BT on 150 but they seem not  to be completely sure. Thanks in advance.
4 REPLIES 4
Message 2 of 5
Re: Digital voice from Telephone over internet
Message 3 of 5
@kjhnor
Yes, that is exactly what you need to do.
Message 4 of 5
Hi Keith thanks for the response.
Message 5 of 5
Thanks for the info.
