Message 1 of 6
Digital voice switch
I was switched over to digital voice last week. Since then my line has developed a crackle. The person on the other end can hear me but I can barely work out what is being said. Any ideas what to do? I have 3 BT inspire phones. I never had this issue before the switch over
5 REPLIES 5
Message 2 of 6
Re: Digital voice switch
have you connected the inspire base unit to the green socket on the back of the BT SH2 instead of the usual wall socket
Message 3 of 6
Yes did that after peeling off the cover on the hub that was hiding it
Message 4 of 6
did you restart the hub after you connected phone base unit?
are you having broadband problems with connection dropping?
Message 5 of 6
I restarted the hub only today, the broadband seems to be ok so far. I read about restarting the hub so have given it a try, will have to wait for another call to see if it has worked?
Message 6 of 6
can you not phone home number from a mobile assuming you have a mobile
