Message 1 of 3
Digital voice
Im about to join bt and will be getting bt digital voice,,
Ive been looking to buy digital voice handset but cant find any,
Will my bt premium handset (090361) be compatible
Thanks in advance,
Already up and running with the hybrid connect, very handy, as my line is not active for 10 days yet
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: Digital voice
You should get choice of a new DV phone or an adapter to connect an existing phone.  However you can connect your existing phone to the phone socket on the back of the SH2
Message 3 of 3
Re: Digital voice
Perfect thanks for your help, as long as i can use use my current handset while i wait to sort out digital voice im happy😁
