Message 1 of 4
Digital voice
I have Smart Hub 2 and my BT premium digital phone is plugged into my Open Reach modem, when digital voice starts will I need an adapter to use this phone?
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: Digital voice
No, just plug it into the hub instead
Message 3 of 4
Re: Digital voice
This results in amessage' Line error fault' on the phone screen
This is removed when I put the phone line back into the modem
Message 4 of 4
Re: Digital voice
That will change once DV is activated.
