Message 1 of 4
Digital voice
Can I connect my hard of hearing corded phone in hub and use the new cordless ones supplied by BT?
3 REPLIES 3
Message 2 of 4
Re: Digital voice
@davefaz56
Yes you can.
Message 3 of 4
Re: Digital voice
You can connect your existing phone to phone socket on back of SH2 and use lke you do now
The advanced DV phone has accessibility option where you can boost ringer or change the tone
Message 4 of 4
Re: Digital voice
Hi @davefaz56,
If you take a look at - How to set up Digital Voice it will give you all the instructions you need to connect your phone to Digital Voice.
If you have any questions, post back and we'll be happy to help.
Thanks,
Paddy
