Message 1 of 3
Digital voice
I'm thinking of moving my Broadband to BT and also taking Digital voice, my question is  can I keep my existing landline number ?
Thanks.
2 REPLIES 2
Message 2 of 3
Re: Digital voice
You should be able to keep your current number but there are no guarantees.  If you read some of forum posts using search you will see some porting ok but some having problems and not able to keep number
Message 3 of 3
Re: Digital voice
Thanks imj.
