Message 1 of 25
Digtal Voice
Hi. I'm due to be changed over to Digital Voice next week. I need to keep a mixture of corded and cordless phones. Does anyone know the maximum REN that a Smart Hub 2 can handle?
24 REPLIES 24
Message 2 of 25
Re: Digtal Voice
Message 3 of 25
Re: Digtal Voice
@GeoffO1
I recently carried out some basic tests on the Smart Hub 2 to determine its power supply requirements and ringing output parameters.  I'll publish my findings, hopefully in the next few days, on a suitable website to which I will post a link on this thread.
Message 4 of 25
Re: Digtal Voice
Thanks for that. I've searched everywhere I can think of but not found any information so far. I'm sure there must be other people who need to know. I look forward to seeing your findings.
Message 5 of 25
Re: Digtal Voice
according to the manual, the number of DV handsets that can be registered via DECT is 5 : https://www.bt.com/content/dam/bt/help/digital-voice/BT_Essential_Digital_Home_Phone_specification.p...
Message 6 of 25
Re: Digtal Voice
Thanks but I won't be using DV handsets. I've got perfectly serviceable analogue equipment that I have no intention of scrapping. The limit of 5 DV handsets is irrelevant, what I am trying to find out is the REN capability of the router i.e. how much ringing current it can supply. DV handsets will supply their own ringing current from the internal battery.
Message 8 of 25
Re: Digtal Voice
Thanks for the link but it still doesn't give a figure for the SH2  ringing capability. It looks as if the answer will be try it and if it works just accept it. It's a bit like my days as an OMI when we were told "The official REN limit is 4 but if the customer wants more and it works, that's the limit"
Message 9 of 25
Re: Digtal Voice
you should be able to use the phone port at back of hub 2 for nomal phones once its configed to your number its nomal phone socket on back of it if you do not want to use the DV headsets
Message 10 of 25
Re: Digtal Voice
Please stop making totally pointless posts that have no relevance to the question asked.
The OP wishes to know the REN equivalence of the SH2 phone port.
