Ridout1
Message 1 of 8
Echo when calling/receiving calls from Landline
Hi, over the past few months the landline at my grandparents house has had a strong echo for the other caller (they can hear their own voice). I'm not sure whats caused this issue as no change/work has been done to anything regarding the phonelines for years. They bought a new set of phones recently in a hope to eliminate the issue but it persists.
I've tried having the base plugged into each of the phone line points (sorry i dont know the techincal terminology) and directly into mains sockets without extention cords/adaptors, Speaker on/off, adjusting call level, everything I can think of but nothing seems to work.
Moreover, my grandparents have called BT already but spoke to an automated system that said it'll be £80 to send out an engineer to identify the issue!!!
7 REPLIES 7
Keith_Beddoe
Message 2 of 8
Re: Echo when calling/receiving calls from Landline
Welcome to this user forum.
Please can you confirm that they are BT Retail customers?
The echo issue can be caused by a number of different things.
See a similar thread https://community.bt.com/t5/Landline/Problem-With-Echo-On-Line-When-Using-The-BT-4600-handsets-not-a...
Ridout1
Message 3 of 8
Hi, thanks for quick reply
Yes, they are retail customers.
That was one of the threads I read before posting but I have just tried plugging the base into the test socket at the master phone socket and still it echos.
Keith_Beddoe
Message 4 of 8
As you can see, there are a number of possible causes, but its unlikely to be anything in their house, if nothing has changed.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
imjolly
Message 5 of 8
why not just phone 151 and get engineer out ?  if you have used test socket and still echo then problem would appear external and there is no £85 charge
Keith_Beddoe
Message 6 of 8
@Ridout1
Have you managed to make any progress on this issue?
Ridout1
Message 7 of 8
Yes, thank you for your help, the engineer came round and it was an outside fault so no charge.
Sorry for late reply been away for a few weeks.
Again thank you for the help it is most appreciated.
Keith_Beddoe
Message 8 of 8
Thanks for the update, as I was waiting to make sure it was resolved.
