Message 1 of 7
Elderly vulnerable customer's line disconnected 9 days ago
My very elderly mother's phone line with care alarm attached was disconnected 9 days ago. Nothing to do with payment just seemingly a mix up with BT and Openreach not being able to work together to supply phone line and/or broadband. As far as I can make out, both companies keep cancelling orders.
She is not in a particularly rural area, phone line was recently digitalised in February and according to one of 'guides', has partial copper wire (?).
I have a new careline ready to go with broadband (her phone line one won't work with it) but she is obviously paying for both as neither can be used as she has no service - and has even had a letter to tell her that she is being charged for ending her contract early. BT decided that it was better to open a new account at her address in my name to make it easier talking to me but yesterday a guide told me two accounts still appeared to be open.
Apart from the many phone calls previously trying to get the whole process started, I have been on the phone to BT every day since the 17th June trying to get her (or any) phone line reinstated so her care pendant will work until something is sorted out with broadband. BT have recently sent me out yet another router - was asked to send last one back due to their cancellation - so just waiting till we are asked to send this one back as well.
I have phoned BT every day; been promised that it would be sorted out; promised phone calls back with updates; told it has been referred to the Executive Complaints Team and still nothing has happened. I am currently waiting yet again for some reply from BT Complaintsbut felt maybe if I ask for any advice here, someone somewhere might have an insight into what I should do.
Ironically, we stayed with BT as we thought it would be straightforward to upgrade her account.
6 REPLIES 6
Message 2 of 7
Re: Elderly vulnerable customer's line disconnected 9 days ago
if your mother has been moved to digital voice I assume she has broadband also from BT.  have you connected the phone to the green socket on the back of the BT router not the previous white socket which was on the wall?
is your mother registered here
https://www.bt.com/content/dam/bt/help/including-you/BT_Free_Priority_Fault_Repair_Scheme.pdf
Message 3 of 7
Many thanks - she doesn't have BT broadband yet or working phone line so we have nothing working to attach to router. She was registered as vulnerable or whatever the terminology was a while ago but I shall pursue your link as well.
Message 4 of 7
sorry did you place an order for broadband and phone for your mother?  if so was it to be a new fibre to the home connection?
if you are still having problems then contact customer resolutions using the email address in the link.  that will get you to executive level complaints and some action
https://www.bt.com/bt-plc/assets/documents/about-bt/policy-and-regulation/our-governance-and-strateg...
Message 5 of 7
Apologies, I have no idea what new fibre means... but she had an old phone line.
We originally wanted both phone and broadband and then after BT/Openreach cancellations, were told that she couldn't have both. So we agreed on broadband which would enable more services in her home to protect her. However, I was assured that she would have a phone line until this could take place - but then she was disconnected and the various orders to do anything at all have since cancelled.
Message 6 of 7
then use customer resolution email in my link and they will help you
Message 7 of 7
Thank you for taking the time to reach out to us, @jayvee1
I can totally appreciate your concerns around this one, and want to make sure we're doing all we can to support your mother here.
So we can take a few more details around this, I've just popped you over a private message.
Speak soon,
Peter
