Message 1 of 4
Essential Digital Home Phone
I can't believe that I am the only one finding it almost impossible to add my contacts to my new phone. I press the book button on the left and add contact comes up. I press Add and am asked for First Name . I typed in DOCTOR but it would not let me go any further because I did not have a second name to enter when prompted to do so. So far I have no contacts on my phone !  I can't find any instructions other than to " Follow the instructions "
3 REPLIES 3
Message 2 of 4
Re: Essential Digital Home Phone
Just put doctor again.
As an aside. Rather than entering all the contacts via the handset it is much simpler to enter just one contact, export the file from the hub, open it in Notepad, copy the first entry and then paste and edit it subsequently for all the other entries.
Message 3 of 4
Hi @vobster1
I have several contacts stored with only one name field used, just press the 'Down' key to go to the number fields and carry on.
I've just added two contacts using just the First and Last name and both stored without any problems.
Message 4 of 4
thanks . I will try this. BT not able to help me
