Message 1 of 3
Extended telephone cord
Anyone aware of any extended telephone cord that would fit in  to back of phone into Smart Hub 2. Cable that connects both at present is very short and BT adaptor not any good.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Extended telephone cord
Not sure what you're asking, do you mean a BT431A to RJ11 cable like this?
If so that's slightly problematical as there's two wiring configurations, so you need to be sure which one you need. Better to just use a regular BT431A extension cable to extend the existing cable.
Message 3 of 3
Thank you for info.
