gw0gvq
Message 1 of 5
Factory Reset
Can anyone tell me please how to factory reset my BT Premium so it goes back to clear everything? I want it to show the setup wizard only I notice when I perform a reset on my Landline it does not reset the phone 100% and this is what I want to do.
4 REPLIES 4
Barney3
Message 2 of 5
Re: Factory Reset
Has anyone had a reply to this question as I am also needing a reply    ????
Barney3
Message 3 of 5
Re: Factory Reset
Hi, I have he same problem as you had about resetting the Premium Phone, did you ever get a reply and did you find out how to do it please.....thank you
pompey1898
Recognised Expert
Message 4 of 5
Re: Factory Reset
Try disconnecting the power for a few minutes and then reconnect
Barney3
Message 5 of 5
Re: Factory Reset
Hi, thanks for the info, now I can restart setting up this phone which is driving me mad. Can we not go back to 2 bean cans and a bit of string.
