Message 1 of 5
Health care alarm
I have a question l have been told by my health care alarm provider to plug it into the router when I change to digital voice will I still be able to use the free digital voice handsets or do l need a ata adapter connect that to the router and the plug in the care alarm to the adapter?
4 REPLIES 4
Message 2 of 5
Re: Health care alarm
Message 3 of 5
Health care alarm
Health care alarm
Message 4 of 5
@Matt132
You can still use the digital handsets, or any existing phones that you have.
Message 5 of 5
When you move to DV you should be provided with a Smart Hub 2, if you don't already have one. This has a standard BT telephone socket on the back (I believe covered by a sticker) which is where you connect your alarm. This should work but you won't know for certain until you try it.
The SM2 is also a DECT base station, so the BT handset connects wirelessly to that. No need for an ATA.
